Identify the changes
What is the best way to determine the changes between two different engineering levels of the same component. Is any special method of overlaying the two parts and identify automatically the changes?
Thank you.
Rob
RE: Identify the changes
the healing wizard has an excellent comparison module.
Thank you JakeLiv.
   If you have DMU space analysis lic. you can use the Copare Products command to compare visually between 2 different levels. gives a good result.
Amit
