API How to get part configurations from assembly
I have an assembly that has a part brought into 4 times with 4 different configurations. I am able to traverse the assembly just fine, but it only opens the part file in the last saved configuration with the getactiveconfiguration call. So I get the same config 4 times.
How do I open up the part file of the current config in the assembly. I tried looking at the referencedconfiguration call with no luck.
SW2006 SP0.
Zuccus
SW2006 SP0.
Zuccus
RE: API How to get part configurations from assembly
This macro can be used in assemblies. Select a component and run this macro. It opens the referenced model and automatically activates the referenced configuration. You decrease the risk of changing the wrong configuration.
http://www.studiozwaard.nl/software/index.html
I will give it a try. It looks like exactly what I am looking for.
