Section view of an Exploded assembly
I was wondering if there is a way to create a cross-sectioned view of an exploded view/exploded assembly?
RE: Section view of an Exploded assembly
bc
If the exploded view is in the ISO orientation, look up broken-out section views in the help file to get detailed information on how to create section view in an orthographic view but apply it to the ISO view.
If you are talking about seeing the 3D model sectioned, there is the Cutaway View command under the View menu. I don't know how/if it applies to the Exploded View environment.
What version of SE are you running? SE v19 made several changes to the Exploded View environment and that is currently the version I have loaded if you happen to need additional step-by-step instructions.
--Scott
http://wertel.eng.pro
Yes, it applies to the exploded view environment.
A draft quality view might be required (depending on the version).
Fred
