Mass Properties question
Hi, Im trying to calculate the Mass inertia of a tool pivoting on a trunion. Can any explain the difference between these values.
Principal axes of inertia and principal moments of inertia:
Taken at the center of mass.
Moments of inertia:
Taken at the center of mass and aligned with the output coordinate system.
Units are values: pounds * sq inches
Thanks for any help you may have
Matthew
RE: Mass Properties question
The tool on a trunion will be pivoting around the center of mass. Does that mean i would use principal axis? The second set of values, taken at the center of mass and aligned with out put coordinate system definition kinda confused me
Firstly, those figures are the second moment of mass
The principal axes of a body are such that the cross coupled terms (Ixy etc) are zero. Typically for a simple symmetrical solid the principal axes are aligned with the 'natural' axes of the body. Even for complex things like a car they are pretty well aligned with the obvious directions.
You need to set up a coordinate system parallel to the axis of rotation, and use that moment of inertia.
Cheers
Greg Locock
