Manning's number for fluids other than water
Is there a resource that lists the Manning number for something like bitumen froth (~50% bitumen and ~35% water with the balance being fine solids)?  Or is there a correlation out there relating the Manning number to viscosity or density?  Any help would be appreciated.
RE: Manning's number for fluids other than water
I am looking to size an overflow nozzle on a vessel that is on land.
Oops.  I got it mixed up with something I'm working on now.  It's actually for a launder with a 9.6 deg. slope.
Well anyway...for flow through a long hole its much easier to use Manning ONLY for water.  There are a number of alternatives that are much more suitable for other fluids.  I like Churchill, no separate Ff calculation required for either laminar or turbulent flows.  You can get it here,
http://www.rccostello.com/PIPEFLOW.XLS
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
BigInch,
your spreadsheet is for piping flow only and may not apply to elam's situation.
Both Manning and Hazen & W. (for open channel) formulae are for water only (or fluid with same or similar viscosity to water - density shall not a problem here).
I really doubt if anything readily available in the world for elam's bitumen froth.
Why not try flowpro 2 . A freeware program for gravity flow of launders and pipes.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
bulkH, Ya, once elam realized it wasn't a pipe flow application, I bailed out.
bulkhandling,
I didn't think anything was readily available, but I thought I'd try anyway, in case someone knew of something.
stanier,
I'll try that.
Thanks all.
Sure you can use launder or other open channels for your bitumen froth transportation. But you may need to have some knowledge about your fluid and to make your design conservative.
The best way may be to do your test and find out the relation between Manning number and viscosity. I hope you'll eventually write a paper about a modified Manning formula for various viscous fluids.
