What spline is this??
Hello all.
Appologies in advance, this seems too much of easy question, but its been giving me real trouble.
I received a spline with these approximate dimensions.
10 Splines
OD 46.2 mm
ID 39.5 mm
Looks like an involute spline.
I am not sure whether it is metric or imperial.
Does anyone know what spline it is, or where I can find out?
Also an Inventor/AutoCAD drawing would be very useful if you could point me in the right direction.
Thanks in advance.
Madness
RE: What spline is this??
It looks like it might be a 6 Diametral Pitch Spline
or a 6/12 spline.  Probably a 30 degree involute
spline.
hi
do you know its country of origin this could help identify if its Module or dp, its not a standard BS3550 spline nor a ANSI B92.1 as the depth is shallow by almost .100" to both of these. its the shallow depth thats bugging me it could be a none standard spline/gear, is there any other info that you can get from it.
                          INVOLUTE SPLINE CALCULATIONS TO DIN 5480
nominal diameter                                            dB     mm      47
number of teeth                                             z              10
normal module                                               m     mm       4
pressure angle                                              a         30.°00´00´´
centre  ( F=side fit, O=Outside, I=Ins )                    F  = centre side fit
Spline Description                                       DIN 5480 -  47x4x30x10x11H 9h
                                           External Spline                     Internal Spline
Shaft / Hub Description               DIN 5480 - W 47x4x30x10x9h          DIN 5480 - N 47x4x30x10x11H
tolerance  DIN 5480                             9h                                 11H
profile shift              x * m   mm       +1.3000                             -1.3000
addendum coeff.          Standard=0 /         0.000                               0.000
addendum coeff.            hap0*              0.550                               0.55
tip-diameter                da     mm        46.200-0.160 (h11)                  39.000+0.160 (H11)
standard pitch diameter     d0     mm        40.000                              40.000
Root form diameter          dFf    mm        39.080 max.                         46.280 min.
root diameter               df     mm        38.200-0.923                        47.000+1.042
base diameter               db     mm        34.641                              34.641
tooth thickness tolerance    T     µm            71                                 140
                            TE     µm            45                                  90
                           T-TE    µm            26                                  50
                         Ase / Aei µm             0                                   0
                         Asi / Aee µm           -71                                 140
                         AseE / Ae µm           -26                                  50
radial runout               Fr     µm            36                                  71
tooth thickness              s     mm         7.784                               4.782
working tooth height min.   hzt    mm         3.440                               3.440
base tangential length over / between           2teeth                              3spaces
       Finish. dimension           mm        19.486 - 0.023                      30.369 +0.121
                                                    - 0.061                             +0.043
                                   mm      = 19.425÷  19.463                   = 30.412÷  30.490
dimension over / between pins      mm           pin  ø 10                           pin  ø 6
       Finish. dimension           mm        59.393 - 0.032                      35.413 +0.220
                                                    - 0.086                             +0.079
                                   mm      = 59.307÷  59.361                   = 35.492÷  35.633
backlash                           mm           0÷ + 0.183                          0÷ + 0.183
Crikey !
Go gearcutter.
I gave you a star on this one!
Thanks all. Especially gearcutter.  Gave you a star too!
Its not correct.  But its about as close as I think I am going to get.
But here's a little more info anyway.
Country of origin. Italy. (not much help) :(
Shaft OD 46.2
      ID 31.5
Hub   OD 46.4
      ID 39.65
Yes these are correct.  Very deep on the shaft.
Can you confirm if the measurments across pins or tangential span, I gave, are the same on the samples?
 The original shaft minor diameter was 39.5 but now you say it's 31.5; are you sure?
 Is the root of the external "full fillet" or "flat root".
 The hub's major diameter suggests that the spline is "top fit". Is there tooth tip chamfering on the external's teeth?
Appologies.  I gave approximate dimensions for the hub first time round.
The hub looks like it is designed for flat root, but the shaft looks as it is a very deep fillet.
There is no chamfering on the external teeth.  But then I also doubt that the shaft is of the original design.
It might very well be "top fit".
Where did you get your info from or is that a secret? :)
Again, can you confirm if the measurments across pins or tangential span, I gave, are the same on the samples?
 To confirm, based on your dimensions, is there really 4.075mm clearence between the shaft minor diameter and the hub minor diameter? This seems like an excessive amount.
 Calcs were done using Excel.
