finding leads on 3 phase generators
I have a procedure to use low voltage DC power source like a battery and a volt meter to ID the leads on a 3phase motor. For example, find all the pairs, flash a pair called 1 and 4 and measure the voltage induced in each of the other pairs with a voltmeter. by the readings identify the other pairs and their polarity in relationship to the first pair which was arbitrarily assigned 1 and 4.
Will this work the same for a 3 phase generator? I would think so, but since some of you have probably done this a few times, I thought I would ask if there is a better way.
A related question, I have an old early 60's 75kW 12 lead Kohler set which has two of it's circuits out of order compared to the "normal" wiring diagrams. For example it is connected series wye 277/480V with L1=T1-T4+T7-T10=N, L3=T3-T6+T9-T12=N but L2=T8-T11+T2-T5=N It works fine, but why do it? Leads on that one are ID'ed with aluminum bands.
RE: finding leads on 3 phase generators
respectfully
