why?? it should be another thing!!
Hi
as you now exp(i*pi)=-1
and as well exp(i*pi)+1 should be 0
but you find it is 1.2246e-016i!!!! in matlab..
does somebody know why???
tnx
RE: why?? it should be another thing!!
Why would you think that a numerical processor has infinite precision?
TTFN
The exponential is an infinite series. If you have an infinite amount of time you can get a better answer.
corus
"If you have an infinite amount of time you can get a better answer"
Not quite, you would also need a computer with an infinite number of bits. That is to say this is a quantisation problem not a time one.
Actually FrancisL since its a converging infinite series any computer will do - you just need a bigger stack of paper in your printer smile
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
So long as you don't use floating point... the source of the rounding errors.
bcd maths would be better...
bcd math would have to be floating point as well, to represent cos().  These are irrational numbers and cannot be represented in any format exactly.
TTFN
That is hat I was trying to say earlier!
Francis
Indeed.
But bcd math doesn't have the binary/decimal conversion error.
clown
The conversion error is at the limit of the machine's precision, so it really doesn't matter whether you were able to express 0.1 exactly in BCD, when there is an infinite number of cases that BCD doesn't help anyway.
TTFN
You can calculate using scaled integers to any arbitrary precision, as long as the function can be reduced to a converging series. About 20 years ago I was teaching a BASIC programming class in which we calculated pi and e to 100000 places using integer arithmetic.
Took some time to calculate though smile
Good Luck
johnwm
