Problem with dimensions bbeing visable...
...hello newbie here with first post...we just installed SWX 07 and are having trouble with the dimensions on our engineering drawings. We use all driven dimensions on our drawings and changed the color to black in the system options but when we DXF the file the dimensions are practically non-existent. I searched through all the options and can not find the proper setting. They also appear very faded on the screen in SWX and I swear I saw a setting or layer or something to make them "appear" as driving in the past but for the life of me I can't figure this out.
Thank you very much for your help,
Bryan
Bryan
RE: Problem with dimensions bbeing visable...
When you DXF, when are dims non-existent? In the other software when importing ... or?
It has been a long going problem when DXF export/import dwgs with any CAD, dims go away.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
What program are you opening the DXF with? I haven't had any problems with ACAD. Maybe your video card is causing these problems.
SW06 SP5.0
Flores
ht
"Upgrade" or "separate install" or "clean uninstall/fresh install"?
Was the anti-virus disabled?
Look for "DXF/DWG Mapping" in the help menus...
Windows XP / Logitech "Premium" Optical mouse
SolidWorks 2006 SP4.1 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
