Hide Pipe Centerline in Drawing
I have a cable assy(.asm) that contains 2 connectors with a solid pipe acting as the cable. I need to hide the pipe centerline from the drawing via layers in the drawing.
RE: Hide Pipe Centerline in Drawing
The pipe centerline is part of the assembly feature (a.k.a the pipe).
You need to make a Layer in the assembly mode and add the Pipe features in that layer. Then Hide the layer in the drawing.
You cannot earse Pipe centerlines in drawing mode, they dont act like axii.
http://www.sprdesign.com
http://www.3dlogix.com
