York YT Centrifugal Specs
1. Do condenser & evaporator pressure drop curves exist for these units?
2. Is there an acceptable oil loss specification for the new style shaft seal, example: 25 ml/week?
3. What's the maximum spec's for shaft alignment? Our measured vertical was 6.9 Angularity, 7.3 Offset. The horizontal readings were fine.
4. What is the shaft seal oil pressure specification?
YORK 450 TON CENTRIFUGAL R123 460 VOLT
M/N YTK3L3E2-CRG
S/N GECM-110268
COMPRESSOR YDTL-120, E2,CD, STYLE F
CONTRACT NO. 94-10311
M/N YTK3L3E2-CRG
S/N GECM-110268
I wish I was more like my dog!
RE: York YT Centrifugal Specs
2. York changes this measurement consistantly. The new bellows style seal is pretty good as far as stopping the seal leak issues.
3. Have to look it up
4. Seal cavity pressure should be set just above atmosphere while the machine is running, just enough to stop it from sucking in air. The books states 1 to 3 PSI if I'm not mistaken.
