Drawing decimal places
I am trying to set the number of decimal places shown in my drawing and I don't want to go through and change everyone individually.
Matt
Pro/E WF 3.0
RE: Drawing decimal places
I'm not using WF3 but in 2001 the config option is LINEAR_TOL
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
config.pro setting is: default_dec_places
Ben Loosli
Sr IS Technologist
L-3 Communications
If it an already existing drawing, you can select all the dimensions at once (use ctrl key) and right click for properties.  Change the decimal place number accordingly.  *** I'm not sure if this still works in WF3.  Please let us know.
Mike - yes you can still select all of the dims and right click in WF3.
However I didn't really want to do it this way because my drawing is for an assembly and is 10 pages long.  I was looking for an option I could change that would force all of the dimensions to 3 places.
Matt
Pro/E WF 3.0
As with most config settings, they only apply to new objects added to the model/drawing after they have been applied. There are very, if any, settings that will change all vlaues without selecting them first for the chnage.
Ben Loosli
Sr IS Technologist
L-3 Communications
The quick way to change all of them is to use the selection filter at the bottom right of the screen. Change it to "Dimensions" and then drag-select a box over the whole sheet. Only dimensions will be chosen. Then hit Edit-->Properties and change the decimal places to three.
I have a few mapkeys that make this easier on me. I.e., When I hit '333', any chosen dimensions go to three decimal places, and so on.
