Electropolishing 301 stainless steel
We are experiencing quality problems with electopolishing .025" thick x 7" round discs of 301 stainless steel. The supplier says that water spots are the cause.
The parts are blanked on a die and then washed. The detergent is an alkaline material and is used in an industrial spray washer with fresh water rinse. Composition by weight % is as follows:
5-10 % potassium hydroxide
5-10 % sodium silicate
10-20 tetrapotassium pyrophosphate
5-10 % 4 Na ethylene diamine tetra acetate
After washing the parts they are heated in an oven at 600 degrees F for one hour. The supplier claims the electopolishing operation will not remove the spots.
Is this possible?
grayseal
Is this possible?
grayseal
RE: Electropolishing 301 stainless steel
Please try it out.
