Circuit board pad layout.
What are the possible manufacturing issues and drawbacks involved in using a pad layout that is exactly the same dimensions as the maximum tolerance of the footprint of the device being installed? Can I get away with having a 7% overhang of the interior "heel" of the surface mount part relative to the pad? Why should I follow an IPC recomended pad layout that takes up so much of my board space when the device will fit snug on a smaller layout?
RE: Circuit board pad layout.
Another caution is to be sure that whatever manufacturing facility you are using is willing to build a board that does not meet IPC and that they understand that this is the case. Document it!
Hope this gives you some confidence in your decision.
