carbon black and TiO2
1st question:If only TiO2 is used do we need any stabilizer for PE pipe in Texas heat (surface: above the ground) since carbon black heats so fast.
2nd question: how much an average black (Carbon black) PE pipe heats up on the sun compared to white (TiO2) PE pipe : Temperature rise
thanks in advance
thanks in advance
RE: carbon black and TiO2
You should probably describe the application, the fluids involved and the requirements.
Maybe you can try
http:
and many others listed in general search result pages.
http://www.welding-advisers.com/
