Help with an intercooler and air conditioner
I have a sealed (pressure vessel if you will) enclosure with electronics (1500-2000W) that is currently designed to be cooled via an air to air intercooler using high flow rates we guess the unit will provide a 5-10 degree temperature rise to amb. If the amb temp is max 55C the inner vessel is 60-65C. The problem is the inner vessel needs to be 45-50C max. So we need an air conditioner to get below amb. Given the intercooler will contribute a large part of the heat transfer how would I size the air conditioner being it is not the primary means of heat transfer?
RE: Help with an intercooler and air conditioner
