Centrifugal R-134a Air Conditioning Unit
Hello all,
I have a 200 ton unit designed for chilled water at 720 gpm and 44F supply.
What happens to the compressor power consumption/efficiency if I increase the flow to 900 gpm but keep the same load and supply temperature?
Simply put, from a kW/ton perspective is it better to have a higher inlet(return) temperature and lower flow? (Assuming UA of the evaporator is constant)
Thanks in advance
Thanks in advance
RE: Centrifugal R-134a Air Conditioning Unit
Aside from addressing the other issues relating to pushing 25% excess flow through a chiller, Your system efficiency will also be reduced: You are pumping more water through the system, your end-user equipment delta-t's are reduced, and your system pressure is higher - particularly in your chiller.
Q = m Cp Delta T.
If "m" goes up, Delta T come down.
HVAC68
I understand that I have decreased overall efficincy because the chill water (CW) flow and pumping power is greater than the design flow for the given load.
I am trying to build a case to add a heat exchanger with a much greater temperature rise than that normally seen with an HVAC cooling coil.
I have power consumption curves for varying condenser cooling water inlet and CW outlet temperatures. But I don't have any for varying CW inlet temperature.
If the evaporator is designed for an average (CW)temperature of 47.35 F with an exit temperature of 44F what happens to power consumption if the CW inlet (and average) temperature is increased for the same load?
Chillers also reduce efficiency for both increased Cond water supply temp and reduced CHW supply temp.
