Problem related to open channel flow in fluent
Hi all,
I am working with Fluent 6.2 in trying to model open channels. In this regard I am facing some problem related to open channel boundary conditions in VOF model in Fluent.
My questions are
1) How to specify different boundary conditions in open channel simulations?
2) Is it appropriate to select two phase model in case of open channel?
3) If i select only one phase(i.e., water) what should be outlet boundary condition (as in case of open channel outlet pressure will not be atmospheric pressure then what should be it's boundary condition)?
4) In case of two phase model if i select some boundary condition and specify some phase(air or water or mixture) to the domain then the others automatically takes the same phase by default. what can i do for it?
5) In time of  2D modeling the open channel in gambit whether it is necessary to create air inlet and water inlet differently by two edges? Or it can be specified by one edge only? How can I specify same inlet group ID for them????
For your kind information i am glad to inform you that i have read the example of VOF in the tutorial guide of fluent. But none of them have discussed about open channel boundary condition. It is simple to simulate pipe flow but open channel is quite different. At this moment i want to simulate a simple 2Dcase where the channel length would be 10 m and flow depth of water is 0.5 m where total depth of channel is 1m. Above the water there is air. I want to input the entrance water flow velocity. At the end outlet water...what should be the boundary condition? It would not be atmospheric pressure because open channel is infinitely long.
 biswanath
RE: Problem related to open channel flow in fluent
biswanath
I'm not familiar with Fluent, so my answers may not be good but...
Generally two-phase means the liquid and gas forms of the same fluid.  It's hard to see how you would have steam in your open channel.  So I don't really think you should be choosing two-phase flow.
Have you considered figuring out your hydraulic diameter and just using that in the program?  I don't have my Crane in front of me, but it's a relatively straight forward calculation.
The one example you give is that the outlet pressure would be above atmospheric.  Could you explain this a bit more.  I'm having a hard time understanding the concept of an open channel that is above atmospheric pressure.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
