Scaling images
Scaling images
Hi there
I have a raster image that i want to scale. my problem is the vertical and horizontal scale factors r not the same(get it write horizontally, but vertically its out). Is there a way of making this work? Stretching it doesn't work.
thanx
thanx
RE: Scaling images
put the image into a block.
Lothar
ADT 2004
ACAD 2002
RE: Scaling images
RE: Scaling images
you can scale a block with different axes. Make a block, only with your image, calculate the scalevalue and scale it in the properties toolbar.
Or, you work with an image software, like Photoshop, etc...
Lothar
ADT 2004
ACAD 2002
RE: Scaling images
RE: Scaling images
"Everybody is ignorant, only on different subjects." — Will Rogers
