Volume of Excavation
I'm trying to figure out the volume of an excavation. I could use other methods, but I am going to try to do this one in AutoCAD.
I know what the current surface is and what the final excavated surface will look like. If I could create these two surfaces then join them to find the volume in the middle, I would have what I want. So what commands/methods are best used to create these surfaces and then determine the volume?
Feel free to link and online articles, etc. that might help me with this.
McVities
McVities
RE: Volume of Excavation
start finding the area at different z depths at
a constant interval. Use 1/2 of the two areas per
each z depth and sum them.
If the hole is not flat bottom and somehat rounded, union a sphere with the above solid at the center line of that sphere to get your hole shape then do an inquiry.
If it is a trench make a rectangular solid box and do an inquiry.
All values will be approximate which you would get with any of the program mentioned above anyway.
i
