Open cooling water tank corrosion
What is the proper way to measure the voltage in a water filled steel tank with a [Cu 1/2 cell]. The tank has severe corrosion and pitting. I want to add a magnesium anode to help slow or stop the corrosion. I would like to measure the potential before and after.
My asumptions are:
The [Cu 1/2 cell] placed at the water surface.
+ meter lead to the top of the [Cu 1/2 cell].
- meter lead to the tank wall.
The voltage should be > (-0.8) volts. after the anode(s) are applied.
Will the anode slow or stop the corrosion?
My asumptions are:
RE: Open cooling water tank corrosion
But did you think of coating the interior with a proper metallic or organic system to protect the mild steel from corroding?
Can you put inhibitors in the water?
I am not an expert in corrosion protection but I have a hunch that it might be difficult to get a uniform potential all over the tank surface.
http://www.welding-advisers.com/
