Why won't guides in Bluesurf command work?
I have a section of a cast component I am attempting to model. I have generated the cross sections and connected them using a tangent continuous set of curves that I want to be my guides for the Bluesurf. The Bluesurf works fine but when I attempt to introduce the guide curves, SEv18 is either ignoring them altogether or retaining the straight line surfaces and just adding a knife thin section that follows the guide curves. I have spent the last two hours going over the tutorials and cannot find anywhere that I am going wrong, I even tried Segurucool's shampoo bottle tutorial from his site and I cannot get it to work either.
Any help would be greatly appreciated.
RE: Why won't guides in Bluesurf command work?
Another problem I could think of is that the guide curve is not connected to all the cross sections.
Just a hunch, hope this helps.
Thanks for the help.
Are the curves connected in the sketch with a connect relationship at the endpoint or pierce point of the other curve?
--Scott
http://wertel.eng.pro
You mentioned in your original post that you couldn't get the bottle tutorial to work from SEGurucool's site. This is an indication that you are doing something wrong. Do you have a file that someone could take a look at for you?
David
Did you try to use Swept surface instead. This should apply the guide curve to the whole surface whereas bluesurf acts more like lofted protrusion (or surface) and only applies the guide curve locally.
Fred
