Concrete Pan Joist Top Slab Thickness
This is a survey: IBC Table 719.1(3) shows 4.6" thickness for 2 hour fire rating when using carbonate aggregate concrete. Do you usually round this number down to 4 1/2" or round up to 4 3/4" or 5"?
RE: Concrete Pan Joist Top Slab Thickness
However, that 1/4" of concrete can be a savings depending on the size of the building.
100'x200x1/4" is 15+ yards of concrete
50'x50'x1/4" is almost 2 yards of concrete
Meanwhile, the Interior designer is trying to decide between the quarry tile at $5.00/SF or the marble tile at $10.00/SF.
