Low density fluids
Low density fluids
Low density fluids
Hello All,
I am looking for fluids with densities much lower than the density of water. I have got the idea to measure very small differential pressures in an u-tube with them.
Many thanks in advance,
Katharina
RE: Low density fluids
Oils (vegetable and mineral), paraffins (heptane, hexane, gasoline, kerosene), alcohols (ethanol, methanol), acetone.
There is a device out there that does this already.  The tube is on an angle so small pressure changes are exagerated.   I can't remember the name of the device.
They are called inclined-tube manometers. Frequently used to measure draft in fired heaters, and very small pressure differences. A google search would show numerous sites.
Manometer (inclined manometer) oil used in HVAC systems has a specific gravity of 0.83. With the advent of magnehelic technology and also evaporation of this oil during fumigation of areas, inclined manometers are becoming obsolete atleast in pharma industry.
I think you'll find that it's hard to get liquids that are a LOT different from water, or at least enough to make a significant difference in a manometer.
I believe you could rig up a manometer with two fluids where the difference in densities did the measuring, which would be more sensitive (and more complicated).
