Flat pattern view of mirrored sheet metal parts?
How do I create one? Do I do an "insert bends" so I can
get a flat pattern to show up in the orientation when
I insert a model view...? I can get it to work, but was
just wondering what the right way is...
RE: Flat pattern view of mirrored sheet metal parts?
Since it is a mirrored part, and therefore identical to the original part, why not just use the flat pattern of the original part instead of the mirrored part?
SW06 SP5.0
Flores
Isn't this the same part either way?...just flip the sheet over before you bend it!
Boottmills soapbox
SW2006 SP3.0
It's actually got a few additional hole features added to
it.
dutch7777 ... yes, you need to use the Insert Bends tool to re-create the mirrored part as a SM part. That's the only way I know of for a mirrored part.
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
