Composites and Mechanica
I tried doing a verification model (simply supported beam) today with a composite sandwich and got very different results. Any thoughts?
Method 1: All solid elements were used for both the thick core material and the laminate. The material properties for the core is isotropic (foam) and the laminate is orthotropic. The problem with this is that meshing is poor for such a thin laminate compared to the core.
Method 2: Core was made with solid elements and laminate was done with shell elements (mid plane extraction from above model). The results between the two methods are drastically different (about 5.75x different!).
The deflection with the all solid elements was alot less then that of the shell+solid configuration. I am trying to figure out why and can't think of the reason so far. I would very much appreciate any insight into this.
Thanks!
RE: Composites and Mechanica
Yous should post this question in the Mechanica Forum:
http://www.eng-tips.com/threadminder.cfm?pid=828
In method 2, how are your shells attached to the solid elements - if they are not attached, this might explain the larger deflection
I think the shells were attached well...I did a modal analysis to see for sure if the shells would move with the core correctly and it did. The interface during meshing was "pink" so it looks like they were bonded as intended.
Thanks for the link to the mechanica forum.
