ASME I, HYDRO TEST
ASME I, HYDRO TEST
I just want to know that, Is ASME sec I, allows leak during hydrotest of boiler with power piping from mechaincal joint (Threaded connection)?
If yes, Which para of ASME I and not Then also which para of ASME I.
Mihir5577
Mihir5577
RE: ASME I, HYDRO TEST
There are three kinds of people in this world; those who can count and those who can't.
and after more than 30yrs, in field and shop work,
the leaks will not seal on inservice,
that's does not fly anymore,
it was called in the pass (and present) rust seal...
it was/is used in plumbing and not in piping.sloppy procedure.
genb
What exactly are you asking? Can you re-state your question?
