Flowable Fill Backfilling Cast Iron Pipe
I have a specification for flowable fill that prevents metal pipes from being backfilled with flowable fill unless coated with some sort of manufacturer coating material or plastic casing. The question has arose from a contractor as to why this is the case becuase the contractor wants to use plain cast iron with no coating or covering. Does anyone know if this will harm the flowable fill (cementious, flyash material), I'm not necessarilly concerned about the pipe corroding? Thank You.
RE: Flowable Fill Backfilling Cast Iron Pipe
