Sizing a battery disconnect switch
Hi everybody,
I am looking for references on how to size a battery disconnect switch.
Any help will be appreciated.
Yigo
Yigo
RE: Sizing a battery disconnect switch
In either case it can be rate higher.
Keith Cress
Voltage you must know, current is based on the load (design load, not only actual). For DC, I=W/V.
Sometimes I only open my mouth to swap feet...
