Sw2007 SP0 stability
Greetings,
I was wondering how everyone who upgraded is making out?
The newsgroups have been pretty quiet.
Any specific problems or concerns?
RE: Sw2007 SP0 stability
I printed out a couple of sheets and the dimension lines were there, but the actual dimension value wouldn't print out until I assigned them to a layer.
Maybe a setting I missed somewhere, but I don't recall having to do that "extra" step with the previous versions.
One annoying thing is that within an assembly when creating a distance mate--the distance between parts is not maintained within the distance box as a starting point--it's instantly changed to a default value (0.100" or 1.000"). But I've heard this is a bug that's already been noticed and will be corrected by a service pack.
Otherwise, the stability has been great.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Only issue with Assemblies for the most part (coming from SW06 to 07) you might have to flip the alignment on them. if the issue is deeper then that send the files to your VAR.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
thread559-165579
Jeff Mowry
