Ideal wall settings.
I'm currently working on an internal flow problem using CosmosFloworks(2005) and was wondering if anyone knows how or if, it is possible to select a external wall face, from the inside, and let the flow pass through it without affecting the main internal flow?
Apologies if this sounds a bit vague. I can explain further if required.
Any help will be appreciated.
