comparsion of short circuit methods
Please contribute to the advantages and disadvantages of the following short circuit methods:
1. Hand calculations: in particular methods of symmetrical components
2. Skm software
RE: comparsion of short circuit methods
Advantages:
1.  Cheap.  Aids in understanding of the problem.  Flexible.  QA possible.
2.  Easy.  Can handle complicated systems.
Hand Calcs: 1960
SKM: 2000
The biggest problem is giving someone inexperienced the software because they do not know when they made a mistake or sometime is not correct.
1. Only practical for very small systems.
2. Practical for everything but very small systems.
Thanks for all the replies
If I'm doing a big calc in SKM, I usually do a hand calc for a couple selected fault locations to "ballpark" verify the SKM results.
If I'm only needing a fault level for one or two locations, I generally just do the calc by hand to keep my skills honest.
