What is solution annealing, pickling, and passivation?
Please explain to me the solution(s) used in annealing, pickling, and passivating SS304, 304L, 316 materials. What is the purpose of this treatment? Is there literature out there that I can download which will go into the details of why this process is used?
After the process is there any detrimental effect to mechanically polishing the surface.
Thanks for your time
RE: What is solution annealing, pickling, and passivation?
Pickling removes existing surface oxides (as from heat treating or welding), surface contamination such as iron from steel tooling, and removes the near-surface layer of metal which is often depleted in chromium due to prior heating. Procedures given in ASTM A380.
Passivation is usually accomplished in nitric acid solutions (or increasingly with heated citric acid solutions). It selectively dissolves Fe & Ni atoms from the surface layers, and oxidizes the remaining Cr atoms, forming a corrosion-resistant surface oxide high in Cr2O3. See 'HOW TO PASSIVATE STAINLESS STEEL PARTS' http://
The highest degree of passivation is obtained by electropolishing prior to passivation. See 'Comparing the characteristics of surface-passivated and electropolished 316L stainless steel"
http
Processing sequence may be:
1) Clean SS of any lubricant which may contaminate surface when heated.
2) Solution anneal.
3) Mechanical descaling (wire brushing, temper rolling of sheet) to fracture & partially remove heat treat scale.
4) Pickle (acidic solution).
5) Mechanically polish.
6) Electropolish (optional).
7) Passivation.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Check out ASTM A-967 “Standard Specification for Chemical Passivation Treatments for Stainless Steel Parts”
Tuthill & Avery, “Specifying Stainless Steel Surface Treatments,” Advanced Materials Processes, Vol. 142 (6), 1992
ht
http
ht
Can anyone go through the details of the solution annealing (what solution is used, temperature, how long?) and then the acids used for the pickling and passivation. Are the pickling and passivation processes carried out at one time or must they be seperate?
The product we produce is a stainless steel well screen used in the water well industry. After dipping the 6 meter screen in a Nitric and Hydroflouric mixture for about 30 minutes, we then wash the screens using soap. Finally the screens are mechanically pollished with brushes. Feel free to critique this method.
Now you probably can understand my choice of "call names"
Please search for & read some info on the heat treatment of stainless, solution annealing stainless, sensitization...
'Solution' means refers to the microstructure of the stainless steel. The SS is heated hot enough (usually in air, but a protective atmosphere or vacuum can be used if you are willing to pay more) to dissolve carbides such as Cr23C6 into the (solid) austenitic (fancy way of saying that the metal atoms have a face-centered cubic microstructure) alloy, and then cooled fast enough that the carbon does not have time to precipitate and grow into carbide phase. Thus, the carbon is said to remain in solution (within the solid alloy).
A solution annealing procedure is given in this thread:
Need for solution annealing
thread330-76941
Re your procedure:
"The product we produce is a stainless steel well screen used in the water well industry. After dipping the 6 meter screen in a Nitric and Hydroflouric mixture for about 30 minutes, we then wash the screens using soap. Finally the screens are mechanically pollished with brushes."
1) It is necessary to know the fabrication details -- are you welding, bending, cutting, grinding...?
2) It is pointless to use soap after pickling in nitric + HF (pickling solution). If oil or dirt is presnt, clean prior to pickling.
3) 304, 304L, 316 & 316L can be passivated in 25-45 vol.% nitric acid for 20-30 minutes, after any brushing. Is this brushing for appearance or for removing weld scale? Weld scale removal should be done prior to pickling; it may reduce the necessary pickling time.
Passivation (+ rinsing & drying) is normally a final process.
Please read QQ-P-35C 'PASSIVATION TREATMENTS FOR CORROSION-RESISTANT STEEL' (free download): http:
In answer to your question, we start with a raw material, for example, of a 4mm diameter SS304 wire. It comes in 100 kg coils. Some is straightened and cut to 6 meter lengths to be used as rods (ribcage) and some is run through a series of rollers to change it to a triangular shape ("v-shape")The dimensions change to say...ht 3 x width 2.5mm.
The triangular wire is then continuously wrapped around the ribcage and electonically welded at each junction. A slot is left between the wraps to allow for water in, sand and particles filtered out. (too much info?)
Normally not necessary to anneal the wrap, never had a problem before.
Rust protection is something we've never had a problem with before either, however, as we move into the "big leagues" we're running into people who know a lot more than we do and sometimes, to be quite honest, like to baffle the customers with bull. (can i say that on this website?) I'm trying to figure out what's true and what's not and at the same time improve my own product.
From what I'm reading out of the replies, my pickling and passivation may be a little lacking. My mechanical cleaning (purely for cosmetic reasons - a nice shiny stainless steel screen) may be degrading the level of protection.
Anything you can tell me is much appreciated
1) Clean prior to welding, to remove any wire drawing or forming lubricant that may contaminate the welds,
2) Pickle, brush and passivate. This sequence gives a more uniform appearance (than brushing first). Use stainless steel brushes.
I presume that you are doing resistance welding and that the screens are used in drinking water wells. If there are more severe service conditions, e.g., chloride in the water, a limited stress relief heat treatment at 290 - 425oC (550 - 800oF), should be carried out after welding. The stress relief reduces the occurence of stress corrosion cracking (SCC), and the relatively low stress relief temperature minimizes 'sensitization.'
See http://www.hghouston.com/ss_heat.html
Use annealed wire rather than cold-drawn, if not already doing so. A high temperature solution anneal would improve corrosion resistance, but does not seem necessary.
It would be less expensive to switch to the low carbon grade 304L, which would reduce the need for annealing (solutionizing of carbide).
The wire that you get is annealed, right? Then you don't re-anneal after forming? This would be the typical process. You want the wire work hardened some in order to raise strength and erosion resistance.
If you haven't seen issues with weld pitting corrosion or stresss cracking then I wouldn't worry about that part of the process.
I am with Ken, I think that you would be getter off washing, and maybe even pickling prior to welding. The cleanliness of the welds should be your first concern.
Are the welds discolored? You need only to pickle enough to clean residual oxides from the welds. You really do need to use nitric/HF for this in order to disolve the oxides. We run agressive pickle, 25%nitric, 5%HF at 130-140F.
Just water rinse after. Pickling is better at removing organics than any wash job.
Polish, and follow the polish with a passivation. Look in ASTM A967 for options. Straight nitric or citric are the most common. We use warm (120F) 25% nitiric for passivation.
By putting the passivation last you will prevent the rust spots or blushing that come from Fe and polish residue surface contamination.
Rust never sleeps
