Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Want to thank those people who have made this forum such a valuable place to visit each day..."
Geography
boffintech (Civil/Environmental)
17 Sep 06 12:51
Does it pay to sandblast concrete testing equipment clean.
A slump cone with hardened concrete on the inside is out of spec.  Wire brush?  Labor intensive.  Acid?  Dangerous and leads to rust.  Sandblasting?  The slump cone is zinc plated on the outside.  If this is removed it will have to be replaced or the cone will rust.  Sandblast then paint it?  The thing only cost $30.  Throw it away?
Pressure meter and roll-a-meter.  Sandblasting?  And then do a seal kit... Or just send it out to someone that does this.
A table top sandblasting cabinet might be big enough to fit the stuff in and clean it up.  But is it worth it?
What's the best way?  Any ideas or opinions?
Thanks in advance.
civilperson (Structural)
18 Sep 06 17:48
Clean with water and fiber brush while concrete is still plastic, (usually before making cylinders). Poor work habits can be modified with the tester replacing coated equipment at his own expense.
18 Sep 06 20:12
Of course the idea is to have the techs clean the equipment with water and fiber brush while the concrete is still plastic; however, what if a tech quits or is terminated and the equipment needs to be cleaned?
"Poor work habits can be modified with the tester replacing coated equipment at his own expense."
Amen brother.
gatorn10ac (Civil/Environmental)
19 Sep 06 18:59
We use a side grider and wire brush. Labor intensive,  sure but can save money. Sand blasting the air meters is ok if you re-spray them with a coating. Tech-Lab in Texas refinishes the air meters. Don't know how much.
brownbagg (Geotechnical)
26 Sep 06 20:06
vinger
Speedycrete (Civil/Environmental)
14 Nov 06 23:21
Try some of this stuff:   http://www.romixchem.com/backset/
14 Nov 06 23:23
HughL (Materials)
18 Dec 06 19:08
If you clean the kit on the same day it gets dirty a jetwash should be all you need when it is brought back to the lab.
regards Hugh
MDL66 (Materials)
23 Dec 06 10:29
Cleaning the slump cone is too labor intensive when you think about the replacement cost (25-30$).  Emphasize good cleaning habits to your technicians up front.  As for pressuremeters or roll-a-meters, sandblasting seems to be the way to go.  Vinegar is not strong enough, and acids are dangerous and expensive to dispose of properly.  We have a table-top spray booth that works very well.  Once cleaned, spray paint the exterior of the meter, or lightly coat with WD40.  The continued application of the WD40 will prevent build-up and painting will make future sandblasting easier.  Don't coat the inside of the slump cone with anything as it may change the slump characteristics when testing.
MDL66
spagetti (Structural)
16 Jan 07 16:43
In my lab we have a 5 gal bucket filed with cider vinegar, you put tjhe air pot in an friday and wipe it clean on monday. it works great for all tools and is very cheap, we change out the vinegar every 2 - 3 months after the initial cleaning, works good on all hand tools asa well and is non-destructive...NOTE do not put the top in it will eventually eat the seals in the pump.
17 Jan 07 17:44
MDL66 SAYS TO USE WD-40 TO PROTECT THE AIR POT, I DON'T RECOMMEND THAT YOU USE IT INSIDE THE AIR POT, WE TRIED THAT IN OUR LAB AND FOUND THAT THE WD-40 REACTS WITH THE AIRENTRAINMENT AND WE NOTED ABOUT A 1% LOSS IN AIR, COMPARED TO THE AIRPOT WITH NO WD-40.  WE DIDN'T DO CORRALATIONS OR ANYTHING LIKE THAT BUT WITH DID DO A FEW SIDE BY SIDES.
labboss (Materials)
18 Jan 07 13:11
Spagetti, your absolutely right.  I guess i wasn't clear enough on that point.  You shouldn't use the WD-40 on the inside of the equipment.  But, when applied to the exterior, it minimizes the amount of concrete that can build-up on the meters.  WD-40 is o.k. on the inside of steel cylinder or beam molds for a release agent.
Labboss a.k.a. - MDL66
Close Box
Join Eng-Tips® Today!
Join Us             Close
