Pipes for Pipe Jacking
Hi there,
do somebody knows if there is a difference between a pipe for jacking into sand using EPB TBM and without using EPB?
RE: Pipes for Pipe Jacking
has the beneficial effect of reducing surface settlements, it results in increased lining
loads in comparison to open mode tunneling methods.”
EPB vs. non EPB should have little effect on the ground pressures exerted around the tunnel. However, when considering axial liner loading, the TBM must exert enough pressure to overcome the design Earth Pressures for EPB operation.
