polyurethane belt adhesive
I have a slipping HTD timing belt. We use custom length endless timing belts that we can't get in neoprene. We've found the polyurethane more subject to slippage/climbing teeth. I sprayed some aerosol glue & it seems to help. Is this common practice or is there anything better?
Thanks, VBK
Thanks, VBK
RE: polyurethane belt adhesive
Not sure of your application, but could you use a polychain belt vs. the timing belt (Gates product) I believe the polychain would minimize the sliping if not eliminate it. You might take a look at the Gates website.
Dennis
SolidWorks 2007 SP0.0
Windows XP Pro, Pentium4 3.00GHz
1.5 GB RAM, Matrox P650
Logitech Marble Mouse, CadMan
Russell Giuliano
