Crank Arm Angle
Crank Arm Angle
Crank Arm Angle
Hi, for a 3 piece crank is the angle (or taper) the same for any length of crank arm?
Ex. If you where standing on the bike and was looking down at the right hand crank arm, you will see the crank arm going out at a angle to miss the chain stay.  Would a smaller crank arm follow the same angled path or the shorter the arm would result in a different angle?  Take a crank arm length of 180mm to 150mm.
Thanks!
RE: Crank Arm Angle
In the bike industry that angle is call "Q-factor".  I think that name was coined by Tom Ritchey if my memory serves me.  It would be the same from one cranks size to the next providing they use the same brand and same bottom bracket length.
Why do you need to know they info?
FYI - it's not that angle that provents the crank arm from hitting the frame it's really the bottom bracket spindle length that you should be concerned with.  Also, if your bike has front chain rings make sure your chain line is correct.
Here is a link for everything bike related:
http://www.sheldonbrown.com/bicycle-links.html
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
