Straight cut Vs "Z" cut in CJP welds of I beams
Hi, does any one can tell me which is the best way in order to join two "I beams" by welding. I have heard that I could use a CJP weld in a straight cut or a CJP weld in a "Z" cut, which of these is the best?
Where can I find a book, web page, article, etc., that deals with this subject?
I think my English is not very good, so I´m including the following image
Thanks in advance
RE: Straight cut Vs "Z" cut in CJP welds of I beams
I believe the straight cut would be the easiest to prepare and weld.
I have concerns fo the Z-cut due to the sharp corners that would be encountered and the difficulty in having the cuts align just so, little room for error.
Good luck - Al
Best regards - Al
Depending on the loading/stresses in the beam where the joint is to be made, you may need a "moment connection."
http://wwweng.uwyo.edu/connections/connection8.html
the picture shows a riveted joint, but welded joints are similar.
I agree with gtaw. The presence of any sharp corner in a weld region is going to increase susceptibility to fatigue crack initiation and propagation.
I would use a straight cut with a Structural Purpose Complete Penetration Butt weld using an electrode matched to the steel, usually fu=480MPa for steel up to fy=300MPa.
You have shown the symbol for a double V butt weld but I would leave that up to the fabricator, so long as he uses a prequalified weld.
This would be for Australia.
