Wide Flange To HSS Col FR Connection
I have a HSS8x8x1/2 Tube Col and W14x30 beams on both sides that form a rigid frame. The design engineer used bolted end plates, but didn't see that the plates protrude outside of the walls. The steel fabricator has contacted me requesting that I come up with a better solution for the FR Connection.
I came across a detail that uses angle straps to transfer the flange force from one beam to the other. Has anyone seen this used before? If so, where could I find literature about it?
Val
Val
RE: Wide Flange To HSS Col FR Connection
Verify the loads and load cases before substituting one connection for another.
We are proceeding to use flange plates top and bottom and welding them to the face of the HSS column with a CJP weld. The reason for flange plates is that the flanges of the W14x22/W14x30 are not wide enough to prevent local yielding of the HSS wall.
Hope this helps.
Val
Val Courtney, PE
Optimal Engineering, Inc.
