Sheet metal - create a dart form feature
Hello guys,
I'm having difficulty in creating a dart in sheet metal. My reference to a dart is a strenghtening crease to a right angled wall. There are no pre-defined form features of this sort in the library. Is there an easy way to generate one.
T I A
SW 2005 sp4
T I A
SW 2005 sp4
RE: Sheet metal - create a dart form feature
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
www.sheetmetaldesign.com...it uses the indent
feature.
I tried to look at the link you supplied but unfortunatly the web page says the server is paused. I'll try later.
examples there that are a "must have"...
I did not find any gusset/dart model
http://www.EsoxRepublic.com-SolidWorks API VB programming help
The link works fine and I found the gusset example, thanks. Just like you I've been using the "brute force" method of using surfaces, and also shelling (clumbsy but it works).
The indent method also works, but the indents have to be suppressed if you want to do any unfolding.
Anyway, Dutch7777 and TheTick, thanks for taking the time to help me out. Keep up the good work.
regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
