WORD DOCUMENTS IN SW DRAWINGS
The assembly drawings that we create at this company contain assembly procedures on the drawing. These procedures can be quite long. I have been attempting to write them in Word and then paste them onto the format.
I am having difficulties in sizing the text on the format as well as editing the text as well. In this case I can not get the left margin of the text to appear on the drawing. The margin can be adjusted when edited in Word, but when you close it it still is cut off on the format.
Is anyone else having difficulty with this? Writing long notes that need to be outline numbered is not very easy to do in standard SW annotation. Or am I doing something wrong?
Any suggestions would be appreciated.
RE: WORD DOCUMENTS IN SW DRAWINGS
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
You should be able to copy all the text (CTRL+A then CTRL+C in WORD). Then switch over to SolidWorks, start a new NOTE and paste the text into this note. You can then change text heights etc.
BANDH
Ken
