PCB mounting hardware
I have a PCB that I need to right-angle mount to a front panel. Does anybody have any recommendations for PCB mounting hardware vendors?
I expect I'll end up with a rectangular cube that is about 0.25" (6 mm) square and 0.5" (12 mm) long with a hole tapped in one end and on one side. Something like a Keystone 1647 (http://www.keyelco.com/pdfs/p61.pdf) could work; I'm not thrilled with the length or the tap size so I'm looking for other options.
In a previous life (job) I knew of a company who produced things like this. I'll post that vendor once I find/remember their name.
Vertical standoffs are fairly easy to come by; any mechanical vendor like McMaster-Carr or Grainger has a lot to offer.
RE: PCB mounting hardware
<tg>
