OFFSET SURFACES FROM A SOLID
I have a solid model in WF2 and I want to select several surfaces to offset to use as a cutter. When I select the surfaces then edit - offset it seem to only select 1 of the original selection. If I copy the surfaces then edit - offset, this works but leaves the original surface which I dont want. Any ideas? (before I do this in I-deas)
RE: OFFSET SURFACES FROM A SOLID
I've been wishing for multi-solidsurface selection with the offset for a long time.
Jason Williams
K Development, Inc.
