Forces on a pipe
Forces on a pipe
Forces on a pipe
Hi all;
I am out of my electrical field and need help. For an idea of what I need here is my problem...
I need to calculate Bending Moment, lateral thrust, wind, and ice loading forces on a 30'long, 4" sched 80 aluminum pipe clamped to a tower mast at the 4' mark of the pipe. How do I calculate this?
Also is there any software available that will generate some numbers on where and when fatigue will happen.
Any help you can offer is MOST appreciated. Thanks
RE: Forces on a pipe
You should hire a structural engineer who's familiar with tower design.  The code to use is the EIA/TIA-222 latest edition.  You'll have to provide him with the design wind speed, the expected ice requirements and the elevation of the pipe.   A 30 foot long aluminum pipe might be too small for whatever you are doing.  You didn't state whether there is a panel, dish or whips mounted on this pipe.
If you certify the adequacy of this pipe, you would be practicing engineering outside of your field.
