Free running multi-vibrator with relays
Some months back, we were trying to wire up a free running multi-vibrator using:
i) 2 relay-contactors, each with two NO (normally open) and two NC (normally closed) contacts, and
ii) a SINGLE plug-in timer (with 2NO, 2NC).
Any thoughts on whether it's possible at all?
By free running multi vibrator, I mean: I've a contact that's in an ON-OFF cycle: ON for a fixed time 't'(set by the timer) and OFF for the same time 't' again, based on the same timer.
Guess I made myself clear...
