Moving an activity
Moving an activity
I am just starting to learn Primavera. How do you move an activity? For example, move it from the first one listed to the last one listed.
RE: Moving an activity
Try adding logic ties to the activities and then "scheduling." Hit F9. Then, go to Tools-Organize and in the lower right corner you will find a Sort By box. Add Sort by Early Start and then press Organize Now. If the activity you wanted to move is the last in the logic sequence, it will now show up as last on the screen.
Good luck.
I would like to add to his comments. Once you have the logic the way you want it you can use Activity Codes to sort/group your activities.
