View Manager, xsection, need to control color of section line boundary
Hi gang, I need your help. I'm using WF2. Here is my problem, I have customers that are familar with UG. When I use WF2 view manager and cut a Xsection, The ALL the yellow curve boundaries confuses them (why don't have a clue). They ask me if I could change the color of the yellow curves (these are the bounding curves of the one part) to other colors.  Like UG does, you can color wire frame in a section to help other understand.
Has anyone done this before.
thanks In advance - Texaspete
