OILING IDLER SYSTEM FOR GEAR LUBRICATION
Dear All :
Material - Aluminum - grade 6061 - T6.
Oprating temperature - 60 / 70 C.
Environment : vapors of sulfuric acid ; phosphoric acid and ammonia.
Application : N , P , K fertilizer dryer.
The surface texture presents a blue coloration on the bushing.
Questions:
1. Could the blue coloration be copper sulfate ?
2. Could the above conditions cause corrosion on that grade of aluminum ?
Thank you.
RE: OILING IDLER SYSTEM FOR GEAR LUBRICATION
1. No, the little bit of Cu (0.4 wt% max) in Al 6061 will be present in the form of an intermetallic and is protected against corrosion by the Al matrix (anodic).
2. Yes, both sulfuric & phosphoric acids corrode Al alloys.  Ammonia does not (except anhydrous, with < 0.1% H2O).
Is Al 6061 the gear?  What is the bushing material?
Thank you for the prompt reply kenvlach.
The blue coloration is on the aluminum bushing.
