Testing Weld Integrity for Butt-Weld Pipe Fittings
I am designing a piping system for a hydraulic power unit (HPU). One leg consists of 3" S160 piping operating at 3,195 psi. Another is comprised of 1 1/2" XXS piping operating at 4,150 psi. Both legs incorporate A106 Gr. B pipe with full penetration butt-welded fittings (i.e. elbows, tees, caps, concentric reducers, weld neck flanges, & weld-o-lets). I do not have a specific code to go by as far as testing procedures for the integrity of the welds. I was wondering what the best method of testing would be for this situation (e.g. UT, X-ray, magnetic particle, 1.5 times pressure test, etc). Any help would be much appreciated.
RE: Testing Weld Integrity for Butt-Weld Pipe Fittings
You may want to consider using API 1104 for weld inspection criteria.
