steep roof puddle welds
Are there any guidelines for puddle welds used to fasten steel deck on OWSJ steep roofs (10 rise to 7 run)?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: steep roof puddle welds
Unfortunately I only have the AWS D1.1, I see that D1.3 relates to sheet metal welding and requirements. I will have to further research. Maybe AWS D1.1 will address issue.
Again thanks.
Maybe an alternate attachment should be used (mechanical anchor) due to steep roof slope.
If you are welding sheet metal, the welding and procedures should conform to AWS D1.3, Structural Welding Code-Sheet Steel. The flat position is pre-qualified and must have a 1/32 inch concavity on the weld. If you want to do otherwise, it would require qualifying a procedure first, then qualifying welders to that procedure.
It would be easier in this case to use mechanical fastening.
